totally lost
Old Jan 11, 2005 | 05:09 PM
300exRidr67's Avatar
Default totally lost
hey everyone im new to this forum & i could really use some help. my 300ex is having some electrical problems. whenever i go to start the thing the starter makes a clunking noise & all the lights & everything just go out.[img]i/expressions/face-icon-small-mad.gif[/img] then i have to jiggle the positive wire on the battery for eveyrtihng to come back on & if i want the thing to start i hafta hold that wire or everything just happens again....im so confused[img]i/expressions/face-icon-small-confused.gif[/img]
Old Jan 11, 2005 | 05:41 PM
Semms40oz's Avatar
did you try to tighten the connection at the battery?
Old Jan 11, 2005 | 05:46 PM
ya i did that didnt help a bit. this thing is so frustrating sometimes.........i have ahd it for four months & in that time the starter has locked up 3 times but always fixed itself then on cold winter days the ignition wont turn at all & i have to warm it up with a lighter so it will turn & now this. its almost like it ahs a short in it?.....
Old Jan 11, 2005 | 06:34 PM
Semms40oz's Avatar
yup it does sound like a short... use a decent volt meter to check the wiring in small sections... as long as the short isn't in the cdi or other sealed elctronics you should be able to find it and fix it.
Old Jan 11, 2005 | 06:46 PM
ok thanks man ill try that this weekend when i have some free time
Old Jan 12, 2005 | 01:08 AM
Badbiker's Avatar
Sounds like you have a bad battery cable or even possibly a bad post on your battery if you have to jiggle and hold things to make it start. I'd bet on the cable, but I did have a battery post fail on a cadillac once, it was on of those phoney side posts.
Old Jan 12, 2005 | 01:38 PM
blue250r's Avatar
take the terminals off the battary clean the contact faces up with some sand paper put a little vasaline on them and put it back together you might find the problem has gone
Old Jan 12, 2005 | 02:42 PM
Markymannn's Avatar
Blue250R is 100% correct. I've had the same problem with my 300EX. I guess so much mud and stuff gets thrown up on the battery under the fender that is causes the connection to short out. I took mine apart and sanded all surfaces, put it back together and it was fine. But I also sprayed all the connections with some sort of battery terminal sealant that I picked up at an auto parts store. It has been fine since
Old Jan 14, 2005 | 04:49 PM
fastblaster00's Avatar
my dads warrior does the same. sand down the posts, connections, and the bolts( as best u can) and make shore u do both + and -
lonerider856
Oct 13, 2023 03:45 PM
Nosniborpapa
Sep 19, 2015 07:07 PM
bvolks
Sep 13, 2015 12:57 PM
bigbear350quad
Sep 11, 2015 12:40 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
