Kodiak CDI box
Old Jan 14, 2005 | 09:48 PM
TrailBlazerguy250's Avatar
Default Kodiak CDI box
Hi guys my CDI box went up , cost me around $225 , does this happen on the kodiaks alot ?
Old Jan 16, 2005 | 11:55 PM
BAYOUMASTER's Avatar
my rectifier went out on mine
Old Jan 23, 2005 | 02:06 PM
hmmm well my damn CDI isnt in yet, suppose to be in last week [img]i/expressions/face-icon-small-mad.gif[/img] o well once its fixed its going in the paper !
Old Sep 28, 2006 | 03:30 PM
TheSuzukiKing's Avatar
A friend of mine is having hell with his Kodiak, I was wondering what symptoms you had when your regulator went out? Whatever happened to his charging system allowed him to pull start it. Then it just quit, took it to the shop, the CDI had went out, replaced the CDI, the original problem was not fixed. I think the original problem, whatever it is, caused erratic voltage to the CDI taking it out.
Quad starts with pull cord only, then display is erratic. Battery is new, but appears to not be in the charging system, or starting system. Stator was ohmed, everything else seems fine. Battery was even placed on a charger, went immediately green.
Wondering if this could be his regulator?
Old Sep 28, 2006 | 04:33 PM
hondabuster's Avatar
Use a voltmeter, accross the terminals of the battery. You should see about 12.6 volts with the key off. Now turn on the key and hit the starter button. What does the voltage drop to?
Now using the rope, or bump start, get the motor running, and read the volts. What is it at idle? What is it at 4000 to 5000 rpm in nuetral?
If you see more than 13 and less than 15.5 volts, when its at 5k rpm....the regulator is fine. If you see more than 12.6 at idle, thats good, but you may not, depending on battery condition.
How are the terminals of the cables going to the battery? Make sure they arent oxidized...just scratch them up, and make the contacting areas shiney, with a file or emory cloth or sandpaper.
Old Sep 28, 2006 | 04:44 PM
squeege's Avatar
My battery cables were found loose severl times....when this happens while riding the display will go crazy with differant numbers....when trying to start I only hear a clicking....thighten the battery terminals and problem is solved
Old Sep 28, 2006 | 05:08 PM
Sweet, all makes sense. Under the same note, this is some info, I'd gotten off of another forum.
my friends kodiac did the exact same thing, went for a run about 6 hours into the ride, machine just quit.. No spark.. He checked all the fuses, battery, everything.. What had happened he had a corrorded ground wire to his cdi box.. It burned out his cdi.. Put a new wiring harness in, replaced the cdi, and machine is running next to new.. Hope this helps.
Old Sep 28, 2006 | 09:54 PM
He called today, picked his quad up from the shop, a wire had shorted to the frame, don't know which wire. But his quad is fixed, ready for a long ride this weekend.
Thanks for your input. =O)
RedRancher
Oct 15, 2020 01:45 PM
YankeeRebel
Oct 6, 2015 06:44 AM
RedRancher
Aug 10, 2015 01:28 PM
Jul 28, 2015 12:12 PM
RedRancher
Jul 10, 2015 06:36 PM
