blaster stalling
Old Jan 16, 2005 | 08:59 PM
articblue80's Avatar
Default blaster stalling
hey guys since its winter should i put a 240 jet in becuase its very hard to start it and when it does start i put it in gear and it just stalls...so could jetting be my only problem or sometihng else?
Old Jan 16, 2005 | 09:23 PM
NBake's Avatar
turn ur air screw in to richen the bottom, if it still stalls at high rpm then richen ur main jet or lower the needle clip down
Old Jan 16, 2005 | 09:32 PM
which is the air screw..and how would i richen it?
Old Jan 16, 2005 | 09:40 PM
NBake's Avatar
diagram air screw should be #20, the air screw determines how much air u allow in while u r at 0-1/8 throttle. by turning the screw in, ur allowing less air to pass and more fuel to flow in, which richens ur mixture. when its cold out, ur stock setting leans out so u need to richen ur setting to get running good
Old Jan 16, 2005 | 09:46 PM
alright thanks! If this doesnt work what else could it be?...ill tell you soon how it goes because im gonna go out and try tightening it now
Old Jan 17, 2005 | 03:37 PM
how much should i tighten it becuase it is not starting still
Old Jan 17, 2005 | 04:04 PM
Shav0's Avatar
don't tighten it at all. If its still lean then you need to increase the pilot one size.
Old Jan 17, 2005 | 04:17 PM
what size pilot?
Pehter
Oct 3, 2024 11:00 PM
Ahtatu
Sep 28, 2015 12:14 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
nastyblaster100
Sep 13, 2015 01:19 PM
