Rule winch on Rubicon?
Old Sep 14, 2000 | 03:43 PM
boots11234's Avatar
Has anyone used this winch setup before. I saw the pictures on www.reddingco.com and it seems very chunky. Also doesnt seem like the mounting area is the strongest location either. Also can you use a plow with this setup.
Thanks
Old Sep 14, 2000 | 04:04 PM
hiofcer's Avatar
I believe the Rule is a good winch but their mount/bumper is just BUTT ugly. Not to mention that is over a couple of hundred more. Stick with the Warn it's more than ample for the needs of a wheeler.
Old Sep 14, 2000 | 06:09 PM
Tree Farmer's Avatar
If a Rule appeals to you, fine. I think if I were considering a snowplow, as you are, I'd take a look at the Superwinch ATV2000; internal spring brake standard, compact, realtively easy to mount, affordable. If you go with Warn, as you originally mentioned, you might want to consider an add-on brake to hold the snowplow blade.
I believe you will be pleased with whatever winch you buy (don't forget the ****** block!).
Tree Farmer
Johnny Mac
Aug 15, 2019 03:13 PM
cboler9
Sep 24, 2015 08:35 PM
patrick.oc123
Sep 16, 2015 03:45 AM
patrick.oc123
Sep 15, 2015 02:45 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
