99 Sportsman belt to tight at idle.
Old Jan 18, 2005 | 02:21 PM
Madcap's Avatar
Default 99 Sportsman belt to tight at idle.
How can I ajust the the belt tenision? Do you loosen the motor mount? I checked clutches and everything looks good It is very hard to shift. I pulled both clutches and had the dealer check them out. All is good. I'm stumped.
Old Jan 18, 2005 | 02:27 PM
CED's Avatar
CED
Why do you say it is too tight ?.Is it creeping.If so ,then you can remove shim in the secondary.If this won't help then you may have to check the center to center distance from the crank to the tranny output shaft.
Old Jan 18, 2005 | 02:33 PM
Madcap's Avatar
Yes if you put it in gear it goes in harsh and grinds and it will move forward. There is only 1 shim in the driven clutch and I tried removing it and it didn't help.
Old Jan 18, 2005 | 02:56 PM
CED's Avatar
CED
Check the center to center distance of the 2 shafts.You should be around 10".
Old Jan 18, 2005 | 03:39 PM
Madcap's Avatar
Thanks, I will check tonight.
Old Jan 19, 2005 | 08:52 AM
braveops's Avatar
ced would you not want to add a shim to get the belt to drop a little so it gets loose?
Old Jan 19, 2005 | 09:02 AM
POLARISFREAK's Avatar
Yep that's right need to add a shim. Most have 2 shims in between the secondary from the factory!
Old Jan 19, 2005 | 09:24 AM
CED's Avatar
CED
You are right,brain fart.[img]i/expressions/face-icon-small-shocked.gif[/img]
Old Jan 21, 2005 | 12:29 PM
Madcap's Avatar
I checked the center to center and it is 10". When I take the driven clutch apart, where should the spacers be? I don't see any at all.
Old Jan 21, 2005 | 12:41 PM
CED's Avatar
CED
They will be at the bottom of the shaft.If you don't have any this could very well be the problem.
slowgsxr97
Mar 18, 2022 03:40 AM
Cummins Driver
Sep 11, 2019 01:22 PM
toonces
Jul 31, 2015 09:27 AM
Mikesohio
Jul 26, 2015 10:51 AM
trouttracker
Jul 20, 2015 11:54 AM
