White brothers E-series quiet core II
Old Jan 20, 2005 | 02:56 AM
Brambles's Avatar
Default White brothers E-series quiet core II
Is anyone running the quiet core in their E-series. I just installed and E-series on my 500 HO and its louder than I would like. They say the quiet core reduces noise by 2-3 decibles. Does this make much of a difference?
Thanks
Brambles
Old Jan 20, 2005 | 08:42 AM
braveops's Avatar
i think in there book it says 4-5 db have you taken it for a rip yet? did it go better?
Old Jan 20, 2005 | 09:28 AM
scramblerXrated's Avatar
i have the first version of the quiet core. it does make a difference, but not much. its hardly worth the $35 the want for the damn thing.
also i noticed that the exhaust pipe gets WAY HOT! so hot, it ruined the e series logo on the side.
(turned it brown) [img]i/expressions/face-icon-small-sad.gif[/img]
X
Old Jan 20, 2005 | 01:15 PM
Brambles's Avatar
Haven't really tested it yet, I took it up the block did a pretty decent high range wheelie, I have to play with the carb a bit, it seemed to have dropped my idle a couple hundered RPM. I installed the dynojet kit the other day, definitly didn't hurt the power. I think I might be a little lean but still no backfireing on decelleration even with the pipe.
Today I am going to install the Primary and Secondary spring, dayco belt, thundershift clutch weights, uni filter and rejet the carb
I also ordered the Quiet core II this morning and it should be here tomorrow or the next day. Then all I have to do is install the dial a jet.
Braveops did you get your email yet?
Did Dennis Kirk charge you the gst and pst?
Brambles
Old Jan 20, 2005 | 01:34 PM
braveops's Avatar
Brambles
yes i just checked i dont know about the pst and gst yet? did they charge you? you cut some of the pipe off?
i want to make it go back to stock if needed
i forgot to ask what main jet were you running ?i run a 147.5 and stock it was a 152 i think i went down 2 sizes if i remember right it has been about 2yrs since i did it i think i dropped the needle to. it realy helped jetting it
Old Jan 20, 2005 | 02:03 PM
Brambles's Avatar
Braveops
In order to slip the muffler on to the existing pipe you have to cut off the donut shoulder that is on the pipe. Take a look you'll see. You don't want to cut too much pipe off but you want enough to attach a coupling to it. I'll show you what it looks like when I get it built.
My jetting was 147.5 and I was on the 4th notch down on the needle. I went to the dynojet a couple of days ago and am still deciding where I want to be with that. When I put the Dial a jet on I will have to lean it out a little anyways, but I think I will get my jetting right before I put the dial a jet on and then when I install it I will just cut my jets back 2-3 sizes and lower the needle one more notch from that setting as per instructions. I think this will be less of a headache. The E-series has a nice cruising sound meaning if you hold a constant throtttle it sounds nice and mellow, it just when you crack the throttle and accelerate it really raps. Idle is pretty loud too, it has quite a POP the sound at idle.
Brambles
Old Jan 20, 2005 | 02:35 PM
braveops's Avatar
if you pull on the choke when riding it can help to see if you are close if it takes off to lean if it bogs to rich this might help to get close. i dont want to ride on the edge but dont want to be to fat on the jetting either
Pehter
Oct 3, 2024 11:00 PM
Whitelx1
Oct 2, 2015 10:55 PM
cboler9
Sep 24, 2015 08:35 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
