Pipes for new kfx 700
Old Jan 23, 2005 | 10:17 AM
two250s's Avatar
Default Pipes for new kfx 700
Hello everyone I recently purchased a 04 kfx 700 .I want to install a pipe but I really don't want to mess with jetting the carb.I would like to install duals .Any susgestions would be appreicated. Thanks again.
Old Jan 23, 2005 | 10:37 AM
7QuadSport7's Avatar
I think alot of people put LTE or looney tune exhaust on, they must be doing something right
Old Jan 23, 2005 | 10:51 AM
poopy's Avatar
for the Vforce get the Yoshi duals they look so awesome. when ever you change a pipe you will have to change the jetting.
Old Jan 23, 2005 | 10:59 AM
tprender's Avatar
Just about any of the pipes for the 700 are good. You will need to change the jetting with any pipe that you get, even if you get just slip-ons you will need to rejet. You will notice a big difference with the new exhaust.
Old Jan 23, 2005 | 03:13 PM
two250s's Avatar
Thanks for the info. I really like the yoshi duals any sugestions on where to get a good deal on a set.When I change the jetting whah should I go to. Thanks again.
Old Jan 23, 2005 | 08:57 PM
Todd400's Avatar
I did alot of research before I bought my duals and talked to alot of guys over at kawieriders and ended up going with the DMC Alien's, Sound awesome and made a load of power over the stock set-up, with a simple main jet swap and fliping an extra $20 for a primary spring change in your clutch you can turn your ride into a beast[img]i/expressions/face-icon-small-wink.gif[/img] & they run about $100 less than the Yoshi's
Old Jan 24, 2005 | 12:55 AM
KevinM's Avatar
The Yoshis probably make the least horsepower of any of the duals. Get a set of HMF's or DMC's and take the money you save and buy a Dalton clutch kit.
Old Jan 24, 2005 | 02:28 AM
Doctorturbo's Avatar
GOT BOOST!
two250s any time you improve the airflow through an engine you have to give it more to drink. To keep the air fuel ratio the same you have to jet up otherwise there is no use to improving airflow on the exhaust end.
Old Jan 24, 2005 | 05:02 PM
chop's Avatar
anyone know what the db levle is for each exhaust?
Old Jan 25, 2005 | 12:08 AM
AZVFORCE's Avatar
No one mentioned the very popular Muzzy equal length 2 into 1. Thats what I got and I love it- v8 sound, 5 1/2 lbs lighter than stock exhaust, and makes very good power. Only thing I would put on other than the Muzzy is the LTE setup.
