05 VFORCE overheating in 15 degree weather?WTF
Old Jan 23, 2005 | 12:33 PM
Cavaselis's Avatar
Default 05 VFORCE overheating in 15 degree weather?WTF
Well this is the first problem I have had, running around all day yesterday in the snow I would get the overheat light.Is this a big deal?How do I fix It?
Thanks,
Mike C
Old Jan 23, 2005 | 01:01 PM
veeman's Avatar
Is it possable the snow has blocked the air flow through the radiator? Even in 15 degree weather air must flow through the radiator.
Old Jan 23, 2005 | 01:06 PM
yamihoo's Avatar
yep, common with sleds as well, radiator probably packed up with snow or ice
Old Jan 23, 2005 | 01:17 PM
Smitty4's Avatar
I believe the problem is the fact that these machines come from the factory so lean... then reduce the temp. by 30+ degrees (compared to what the temp. at the California factory was at the time) and you've got super-lean.
I'd try backing out the fuel screws each a 1/2 turn (more if needed) and see what that does. That may help some.
Mine has always run blistering-hot, but due to the numerous problems I've had this past riding season, I no longer work on- or ride mine!!
Old Jan 23, 2005 | 05:10 PM
Cavaselis's Avatar
I just went out and looked and the radatior is clogged with mud.Easy fix thanks for the help I will have to start watching that better.I have never owen a bike that is liquid cooled before.
Thanks
Mike C
Old Jan 23, 2005 | 06:53 PM
deerchooper's Avatar
you have to watch over heating these machines. you can warp the heads or do even more damage. keep an eye on that light.
Old Jan 23, 2005 | 10:49 PM
kawakasi's Avatar
Smitty 4
Correct me if I am wrong here, but I thought these machines
were assembled in Lincoln Neb. ?????
Kasi
Old Jan 24, 2005 | 08:49 AM
yamihoo's Avatar
Hey good to see ya got the fix!
MikeyBoyesq
Sep 22, 2015 10:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Elkaholic
Sep 6, 2015 02:44 PM
Sep 2, 2015 11:15 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
