Asphalt Setups for 1/8 mile drag racing
Just trying to figure out which way I should go, this year, I will be mainly running mine at the drag strip. I am going to probably be spraying if everything works out(20-25hp). My main question is what gearing is everyone running at the track? I will mainly be running 1/8 mile and will probably buy some 20" flat track tires. My current gearing combo w/20" has me topping out at high 84s on GPS. I am guessing it will probably be close if not topped out early by the way it runs out, then when I add the gas its going to be that much worse. Is anyone running a 17 front with 20s and know whay kind of difference it will do, and possibly geared down in the rear.I know that all these ds's out there more than 3-4 run on the drag strip. Any other advice that you can come up with will also be appreciated.
PS. I am not planning on running a wheelie bar.
Justin
Justin
Logan Collins
Sep 5, 2015 08:03 PM
