One more question......
Old Jan 26, 2005 | 11:03 PM
700atWASHINGTON's Avatar
Default One more question......
My speedometer now jumps all over the place whether I am moving or not, Would I be right to assume I need a new speed sensor? Or would a low battery cause this? It is over three years old and sometimes flashes if I run all my lights at idle.
Thanks
Old Jan 26, 2005 | 11:23 PM
jeffro206's Avatar
700atwashington, sounds like the speed sensor. as far as the lights it could be a couple of things:
1 do all the lights and speedo flash? and does it take a couple of minutes for it to start doing it?
2 do they work ok above idle or still the same?
Old Jan 26, 2005 | 11:37 PM
Doctorturbo's Avatar
GOT BOOST!
Check all your grounds and connections.
Old Jan 27, 2005 | 12:44 AM
None of the lights flash, I just get the battery signal flashing sometimes when I first start it up, if I rev it up it usually goes away.
4x4marvo
Mar 7, 2006 10:02 PM
Topper
Oct 15, 2005 03:12 AM
jetjock16
Nov 21, 2002 03:38 PM
jetjock16
Nov 13, 2002 11:58 PM
