Arctic Cat 90 Stator Output?
Old Jan 27, 2005 | 12:45 PM
Tdad's Avatar
Default Arctic Cat 90 Stator Output?
I have an 2002 Arctic Cat 90, can anyone tell me what the stator output is? Also my key switch has 3 positions "Off" "On" and another "On" which I think is for a lighting circuit, am I correct? The owners manual says it has a simple on/off key switch.
Old Jan 27, 2005 | 02:38 PM
Cmymud's Avatar
On my AC 300 that is the way it is. Off/On/On with Lights.
On a side note: How do you like the AC 90?
I'm looking at 2 right now. Guy has a killer deal I'm getting ready to jump on.
Old Jan 27, 2005 | 03:40 PM
toyz4me's Avatar
I have a 2002 arctic cat 90 2 stroke and have had no problems with it. Stock it is one of the slowest due to a huge rear wheel sprocket. With a few mods it can be one of the fastest. The chain on the older ones is crapy but cheap to replace.
Old Feb 5, 2005 | 11:12 AM
fire1177's Avatar
The third position is for the tail light. They did not come with a headlight. We have a 2004 model and are having great difficulties in starting it. On the New Cat 90 carb problems forum we found others with problems and we wondered if the 2002 model also had difficulty starting and idling in cold weather?
Old Feb 5, 2005 | 02:32 PM
spike99's Avatar
I don't know the AC 90's stator "power generation output" numbers, but here's some ideas on how to obtain it:
1 - Purchase a Digital Meter. They are usually between $18.00 -> $28.00 at your local automotive hardware type store. For a picture of our tool, surf: - Press Here -
2 - Second step is to learn how to use the 12V side of your new tool. For details, surf: - Press Here -
3 - Give it a try.... Start your AC-90 unit and let its engine warm up. After warmed up, disconnect the battery and ensure the live wire isn't resting on the frame. If necessary, please a little cardboard under it - as a resting pad. Also ensure the tail of your AC-90 unit is jacked up. By using the tool from step 1 (set on 12DC testing) and your detailed instructions in step 2, obtain the meter readings across your black "-" and red "+" wires. Start with engine running at idle take a meter reading. Then, rev it up to 1/2 throttle very slowly and take another reading. From the WATT output numbers going into the battery, divide by 2. The divided number is your "on average" max watt of light bulb(s). This way, your front lights will work and your battery can still charge at the same time.
NOTE: I haven't tried these above steps myself. But from a white board perspective, these steps should work.
Hope this helps...
Old Feb 7, 2005 | 02:04 PM
Cmymud's Avatar
I'v had my 2002 AC 90 about a week and it cranks and runs Great!!!!!!
Old Feb 8, 2005 | 12:13 AM
Jeramief's Avatar
I just recently purchased a AC 90 4 stroke. For my son If it sits for more than a couple weeks it is very hard to get started it has an automatic choke other than that I have no real complaints.
Old Feb 8, 2005 | 09:55 PM
Cmymud's Avatar
Any luck ?
Old Sep 20, 2011 | 09:50 PM
ArcTic cat 13's Avatar
Originally Posted by Cmymud
Any luck ?
What's the connector for in the front of it for? I was wondering if I could hook a head light to that? Anybody know?
ultangler
Nov 30, 2024 01:35 AM
Customer Service #1
May 15, 2020 08:46 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
kbazzy
Sep 26, 2015 11:26 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
