Help with race pipe on trail mod
Old Jan 27, 2005 | 10:30 PM
EAB's Avatar
EAB
Default Help with race pipe on trail mod
I'd like to get a race pipe because I like the look and fit better than my trail pipe. I know the best thing to do would be to get the race port also, but I cant do that right now. I was wondering A) would there be a gain/loss in the low/mid/full throttle and if so how much B) would I need to change the rear helix or would spring/weight changes be OK (I have a 45/40 right now) C) would there be any other changes needed that I didnt think of.
Right now I have a Bubba trail port, HSP adjustable trail pipe with 2 shims in, 39PWK with a clamp on K&N, trail lightened flywheel and .025 milled head by azbadboyz, V-Force Delta 2 reeds and a spacer.
Old Jan 28, 2005 | 03:18 AM
jeffro206's Avatar
couple ?'s 1 what type of "race pipe"?
2 what is your set up in both clutches? primary spring/ weights, secondary spring, set in what holes, roller rear?
3 what is your style of riding? dunes only, little of everything, woods trail??
give us some more info if you can. thanx
Old Jan 28, 2005 | 07:09 AM
duneaholic's Avatar
Look up KevinM. He's got this setup that you're wanting.
Old Jan 28, 2005 | 10:23 AM
Bubba297's Avatar
The 45-40 split helix would be great for drag racing only, but for an all around helix I wouldnt run it. Go back to the original straight 40 helix. The clutching wouldnt have to change from the regular race setup. The engagement needs to be higher than a trail pipe. I know we can set it up to engage fairly low and with the trail porting it will still have some good bottom end. It might not be as snappy on the bottom as the trail pipe, but the mid to top would be better. If leg heat is the main concern, then I think you would like the change.
By the way, the difference in power with the trail and race porting is tremendous when running the race pipe. It goes from a good running bike to an arm ripper when the porting is changed, so keep that in the back of your mind. Along with race porting you will want to engage a little higher as well.
Old Jan 28, 2005 | 11:16 AM
dailyrider's Avatar
EAB, come over and we will talk There is a few race pipes you can go with. And as for the clutching I will work with you (trade out or something).
Old Jan 28, 2005 | 03:42 PM
Bubba297's Avatar
Hey Dennis, trading is not allowed. Just kidding. He is lucky to have someone close enough to help him work these things out.
Old Jan 29, 2005 | 12:00 AM
EAB's Avatar
EAB
To answer a few Q's
what type of "race pipe"? I like the style that has the chamber curled up in the front, then runs a pipe to the rear...like azbadboyz pipe[img]i/expressions/face-icon-small-happy.gif[/img]
what is your set up in both clutches? I have a brown HPD primary spring with stock weights up front and a violet HPD in the 2-2 in the rear... and a brand new belt because I tried to go over some rocks and it smoked
what is your style of riding? I do alot of dune riding and some desert trail riding
duneaholic- I looked at KevinMs pics and I'm trying to get away from that style pipe, the big chamber under your leg.
Bubba- so put the stock helix back in? Should I try that now or do it if I get this pipe? P.S. I'd like to get the race port done but I have to do it when my wifes not looking
Dailyrider- (in a whisper)..I'll see you tomorrow for that new belt
Old Jan 29, 2005 | 01:19 PM
duneaholic's Avatar
KevinM has the CPI and is alot like the HPD Race Pipe and AZ Bad Boys pipe. This pipe is far away enough from my leg for me compared to the HPD Trail Pipe. I can't get a picture of how the AZ Pipe looks cause I've never seen one on a bike. Hint Hint.[img]i/expressions/face-icon-small-smile.gif[/img]
Old Jan 29, 2005 | 02:10 PM
1fastpolaris's Avatar
Ill try to get some pics up when I can figure out how to do it. Every time I try it keeps telling me that its too big.....I wish i had that problem elswhere.
Old Jan 29, 2005 | 02:20 PM
duneaholic's Avatar
LMAO.[img]i/expressions/face-icon-small-happy.gif[/img]
Asaran
Oct 8, 2015 11:14 AM
MikeyBoyesq
Aug 10, 2015 11:11 AM
traumajunkie
Jul 23, 2015 02:10 AM
rm6keith
Club News and Events
Jul 17, 2015 08:22 AM
Robinhood
Jul 13, 2015 09:13 PM
