50 hr checks
Old Jan 28, 2005 | 07:30 PM
Bloombastic's Avatar
Default 50 hr checks
Old Jan 28, 2005 | 07:36 PM
oops,
I just hit my 50th hour and was wondering what all should be done for the 50 hour services. I changed my oil and oil filter at 20 hours. I have not had any problems thus far, but want to do the routine services to keep it that way. I own the official service manual and don't feel like paying someone else $60.00/hour to do things I can do. So what all needs to be taken care of? Thanks in advance.
Bloom
Old Jan 28, 2005 | 07:44 PM
thewayout420's Avatar
read the maintence section of your manual,it will tell you everything that needs to be done..
Old Jan 28, 2005 | 07:45 PM
20045SP500HO's Avatar
At 50 hours i would change all fluids ... if you do it your self should be under $60 for all fuilds and around $100 if you flush the radiator. cheap peice of mind IMO.
Old Jan 28, 2005 | 07:59 PM
Ed99's Avatar
I am getting a factory service manual for a 2005 500 for 39.95 from a Polaris dealer. He had to order it. I plan on doing all servicing myself.
Old Jan 29, 2005 | 01:37 AM
Kushman's Avatar
The manual tells you everything you need to know. Sit down and read it front to back
Old Jan 29, 2005 | 01:54 AM
elkbow's Avatar
I would do everything, and actually more often than the 50 hours....I've never had problems with my machines as I change fluids often...its cheap....
Change your engine oil and filter....
Change your front differential fluid....
Change your rear differential fluid....
Change your transmission fluid....
Put grease in your grease fittings....
Go through your machine and check all bolts and nuts that you can get to for tightness.....
Check your brake pads....
Verify your cooling fluid level is correct....
Check your brake fluid levels is correct....
Doesn't hurt to put in a new spark plug....with correct gap....
Make sure your air filter is clean and good, if not replace....
dave
Old Jan 29, 2005 | 07:50 AM
Thanks everyone!
I am going to get started this morning, but first need to crank up the heat in the garage. Thanks again.
Bloom
slowgsxr97
Mar 18, 2022 03:40 AM
COFatboy
May 2, 2020 12:06 AM
Blueholleroffroadpark
Where to Ride
Jul 30, 2015 05:39 PM
Johnclay
Utility ATVs
Jul 19, 2015 10:00 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
