600sp spark plug help
Old Jan 29, 2005 | 01:41 AM
chaff's Avatar
Default 600sp spark plug help
Hi all! I was wondering if someone out there would know if it would be all right to put a hotter spark plug in a sportsman 600 (2003). They run 7's in them. I've heard it would be ok to run 5's or 6's. What do you think? Reason I am asking is I run my ATV in cold weather and heard a little hotter plug can make it run better. Thanks for your time Jason.
Old Jan 29, 2005 | 01:47 AM
jeffro206's Avatar
chaff, ive ran both the 5's and 6's in 600's another thing on your quad, has it had the carb and cold weather updates done to it? these will make a considerable difference.
Old Jan 29, 2005 | 02:10 AM
chaff's Avatar
I haven't done the updates (bigger fuel lines, and bigger Jets). Just for the simple fact that in warm weather you would have to change jets again and it becomes a pain in the ***. It's ok in cold I just have to let it warm up for about 15 minutes before riding it (plowing snow). I can't complain to much I wouldn't want to start when temp is below 0F. It always starts but if you don't let it warm up it will stall. I just thought maybe a hotter plug might work a little better. Winter in NY sucks. Later Jason.
Old Jan 29, 2005 | 02:29 AM
jeffro206's Avatar
chaff, the updates aren't just bigger stuff. a dealer can install the update for you. it consists of different jet, jet needle, needle jet, slide spring and adjusting. these should be able to be done under warranty, even if out. and after done you won't have to rejet for weather. unless you do a bunch of other mods. check out the posts under " 600 hesitates and backfires" this will help you out. if your dealer won't help out or doesn't know, then PM me and we'll get it straight.
Old Jan 29, 2005 | 02:41 AM
chaff's Avatar
Ok, will do thanks for all your help. Jason.
Big bousse
Sep 26, 2015 10:42 AM
cornermike
Jul 30, 2015 06:37 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
Dirtbikemike1
Jul 21, 2015 04:13 AM
