polaris hubs
Old Jan 31, 2005 | 01:02 PM
yunt2ride's Avatar
Default polaris hubs
Just wondering if the rear hubs from a 2003 model 330 magnum straight axle will fit a 2000 model 325 magnum. My 2000 model has 10inch wheels and my cousins 2003 330 magnum has 12 wheels standard. So I was thinking if they would fit I could get some of them, then use most any polaris 12inch wheels. I so want to get a set of 12 inch mud tires all the way around.
Old Jan 31, 2005 | 02:08 PM
GE4x4's Avatar
You don't need to change hubs to use 12" wheel's. You both should have the same bolt pattern. As far as useing other Polaris 12" wheel, I could be wrong, but I believe your bolt pattern is 4/4 while most utility Polaris are 4/156. So your use of of wheels will be limited. Another option is putting Predator hubs on your Magnum with the 4/156 or 4/110 pattern and you will have unlimited access to wheels. I believe Polaris uses Team axles on all there solid axle atv's so all there hubs will fit each other.
Old Jan 31, 2005 | 03:39 PM
yunt2ride's Avatar
His 2003 magnum has the same bolt pattern as the front wheels while mine are different in the rear. I noticed this on IRS before but never really looked at his real close before yesterday.
Old Jan 31, 2005 | 04:43 PM
GE4x4's Avatar
OK then Polaris did change, so yes they should fit. But before you buy them, take your buddies off to see if they do fit.
Old Jan 31, 2005 | 04:57 PM
yunt2ride's Avatar
Thats what I was gonna do before I got them but getting together sometimes does not always work out. I will get it done and update everyone because I know there are others that would like to change also. I just figured I would take a chance on someone that may have already tried it, or maybe a polaris mechanic could speak from experience. Thanks for helping out.
Cole Hadden
Jun 15, 2025 09:05 AM
Ramman1
Aug 11, 2022 01:53 PM
NoJoke
Aug 9, 2015 12:39 PM
Polaris Side by Sides
Jul 30, 2015 12:14 PM
maxjung
Jul 13, 2015 05:11 PM
