Scrambler 500 transmission concern
Old Feb 1, 2005 | 06:52 PM
woodsyammy48's Avatar
Default Scrambler 500 transmission concern
I have a 2000 scrambler 500. When I put it in reverse and try to go it pops out. When idling in nuetral has a metalic noise??? HELP!!!
Old Feb 2, 2005 | 07:42 PM
NorthXav's Avatar
I had to change my transmission's chain last year.
If you wait few months, the chain will break in the case and it's very expensive at this time.
The chain costs about 60$
Old Feb 2, 2005 | 08:54 PM
jeffro206's Avatar
woodsyammy, found this post after replied to you other. getting better idea of problem. definitely internal. could be a shifter fork problem. ive had them wear and not want to hold in gear. it could also be bent.
Old Feb 2, 2005 | 10:21 PM
well looks like it will be coming apart..according to my manual there is two chains in this trans?? which one are you talking about and how do I check it once it is apart?
Old Feb 2, 2005 | 10:30 PM
NorthXav's Avatar
#54
HERE
Old Feb 4, 2005 | 02:17 AM
Bladebite's Avatar
have you tried simply adjusting your shift linkage? This is usually the source. Sounds like you're not all the way in or out of gear.
Old Feb 5, 2005 | 11:46 PM
Figured out the problem.
I pulled the quad into the garage today, and when i was looking at the linkage, I noticed a crack in the case. I followed the crack to the bottom of the tranny where it ends up being about 1/8 in wide
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
r1pilot83
Sep 27, 2015 07:38 PM
WilliamBos
Sep 22, 2015 04:07 PM
