steering stem question? - tusk bars?
Old Feb 1, 2005 | 11:53 PM
bahaman's Avatar
Default steering stem question? - tusk bars?
My wife’s DS was rolled by my sister last weekend and I have the typical bent stem and bars as a result. The stem is barely twisted and I was wondering if it is a bad idea to trim out the steering with the tie rod adjustment to bring it back to straight. Also, I have been doing some searches on handle bars and was wondering if anyone is using the Tusk T-7's. I don't want to spend allot on the bars since the quad is my wife's and doesn't see allot of use or abuse. If so what bend is recommended and do you need a spacer? Thanks for the help.
Old Feb 2, 2005 | 01:05 AM
sandbomber's Avatar
Boy!!! hate to make that call without seeing it
Old Feb 2, 2005 | 05:14 PM
BOMBSAINT's Avatar
I have the t-7 bars and i have not had a problem. i put them through some abuse as well. you have got to get the raptor bend for them to fit with out hitting the tank. i found out the hard way. i now have a set of "universal fit sport quad" bars collecting dust.
Old Feb 3, 2005 | 01:05 AM
bahaman's Avatar
Anyone had any luck straightening the steering stem? Mine is slightly twisted at the bar mount but not bent.
Old Feb 3, 2005 | 01:11 AM
sandbomber's Avatar
Why not adjust, drill a little out, space to make up the difference
Old Feb 3, 2005 | 11:06 AM
TBD's Avatar
TBD
If you try to take the twist out by adjusting the tie rods then your stops will be in the wrong position and you will not have the same turning radius in both directions.
Old Feb 3, 2005 | 01:13 PM
sandbomber's Avatar
A new stem is the only way to go!!!!!!!!!! cant be that much
Old Feb 3, 2005 | 05:13 PM
jackass650's Avatar
$135.00 from the dealer, i have a bend in mine, I am just gonna get the pipe from a local steel fabricator but it is gonna be 1 1/2 inches longer and weld the top and bottom mounts on and then i can fit any handlebars i want, shouldn't be anymore than $65.00 that way, there are numerous posts on here about a couple of guys doing this and liking it, just my 2 cents
STLyamwar
Jul 25, 2020 04:44 AM
toonces
Aug 5, 2015 05:55 PM
Sportsman850
Jul 31, 2015 04:25 PM
1966F100
Jul 12, 2015 03:08 AM
1966F100
Jul 12, 2015 03:01 AM
