Wiseco-JE-Ross PISTONS??? Which one
Old Feb 3, 2005 | 01:58 AM
Wes350x's Avatar
Default Wiseco-JE-Ross PISTONS??? Which one
I am going to start buying parts to do an engine rebuild on my 400ex but I am stuck on buying a piston. I have always used wiseco, but I dont see alot of people on here use them. How much better can JE or Ross pistons be? I plan on a 416 around 11-1 comp. Info would be appreciated. Also do head studs need to be replaced with this or not?
Old Feb 3, 2005 | 04:46 PM
ONEANDONLYDWT's Avatar
I was in the same spot. If the price is around the same I would go with a JE. I hear they are made from a little better metal. I will be buying a Wiseco since the one I want is about $80.00 cheaper than a JE. I dont thing you need to change the head studs but I'm not sure.
DWT
Old Feb 3, 2005 | 09:30 PM
ZBlaster's Avatar
Ross... no questions asked....
Old Feb 3, 2005 | 10:49 PM
TractorPacker's Avatar
Do you have a balloon?
I have a 440 stroker. It is a 87mm (416) JE piston. It is 11:1, run on about 100 octane. It has about 2 years service. We took it out and bored a different cylinder, put new rings on it and are re-using the piston. I couldn't believe how good the piston looked compared to the cylinder.
Old Feb 4, 2005 | 12:27 AM
Wes350x's Avatar
Where are good places to find JE or Ross at, with good prices also. Also does anyone know whats the highest compression I can run with 93 octane?
Old Feb 7, 2005 | 02:44 PM
Wes350x's Avatar
anyone else?
Old Feb 7, 2005 | 03:00 PM
cals400ex's Avatar
the je and ross 416 pistons are 10.8:1 which is about as high as you want to go on pump gas. i would call up C&D racing or GT thunder for the parts. the ross pistons are lighter than the original je's. however, i don't know anything about je's newer lighter pistons that they have.
exmotocrosser
Sep 13, 2019 06:12 AM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
nastyblaster100
Sep 13, 2015 01:19 PM
