? on reeds
Old Feb 4, 2005 | 11:11 PM
pooboy2's Avatar
Default ? on reeds
will it help performance if I go with a aftermarket reed but the stock cage?
thanks
Old Feb 4, 2005 | 11:18 PM
RAJ's Avatar
RAJ
Default ? on reeds
I would get the V-Force reeds with the cage and all, and if you want better trottle response get the reed spacer.
Old Feb 4, 2005 | 11:26 PM
Kudzu's Avatar
Default ? on reeds
New reeds in the stock cage may seal better than your old ones, so no air/fuel mix will escape back. That may give you slightly more air/fuel into your engine, but an immeasurable amount in actual practice. Aftermarket cages like the V-Force give more volume by their design, and thus measurably more mixture making it into the cylinder. That is a long winded way of saying you probably won't see much difference with just reeds unless your stockers are really worn out, but you probably will with a set of V-Force or similar.
Old Feb 4, 2005 | 11:28 PM
pooboy2's Avatar
Default ? on reeds
thanks I will go with the v-force set then thanks guys!!
Old Feb 4, 2005 | 11:29 PM
thewayout420's Avatar
Default ? on reeds
do you have a pipe&clutch kit brad?
Old Feb 5, 2005 | 12:12 AM
pooboy2's Avatar
Default ? on reeds
well i am running a hpd pipe with what I belive is a plane cluch spring air box mod with k&n, 1 tooth lower front sproket. that is about it
Old Feb 5, 2005 | 12:23 AM
Default ? on reeds
id get a clutch kit made for the hpd pipe and then the v-force reeds if you have the money..
Old Feb 5, 2005 | 12:29 AM
pooboy2's Avatar
Default ? on reeds
one of the local dealers hade a set of the Boysen reeds laying around said I can get for 20.00 just didn't know if they would help what do you expect for $20.00 I guess also a quick ? I am running a 320 main jet by what I have seen I guess that is high but the plug looks nice an tan just wondering you thoughts ? thanks for the help!!
Old Feb 5, 2005 | 12:50 AM
Default ? on reeds
your machine is stock except for the pipe?if so the 320 jet is way to big.i think hpd sent me a 260 to use with their trail pipe,right now with the mods i have im running a 310..
Old Feb 5, 2005 | 01:03 AM
pooboy2's Avatar
Default ? on reeds
that is my thought but I was always used a stock air filter when I bought a k&n i had to put a 320 my 300 jet was spitting and spuddering till i put the 320 in i quess it runs good i'll leave it alone still sounds high to me [img]i/expressions/face-icon-small-smile.gif[/img]
