creeping in gear
Old Feb 5, 2005 | 07:17 PM
firehouse5's Avatar
Default creeping in gear
[img]i/expressions/face-icon-small-sad.gif[/img]I have a polaris sportsman 500 year 2000 my problem is that it will creep when in gear i have put a new drive and driven clutch on but still the same problem also a new belt any help would be great
firehouse5
Old Feb 5, 2005 | 07:25 PM
thewayout420's Avatar
your belt deflection is to tight,add a shim to the secondary clutch and it should be fine..
Old Feb 5, 2005 | 07:26 PM
brainiac213's Avatar
did you replace the spring in the drive clutch or just swap it to the new clutch? if you didnt repalce it then that could be your problem...the spring has lost tension....
or....
if you have submerged it in water ever and, got water in the clutch cover...your clutch could be hanging up on the inside of itself because it is corroded. this would make the atv creep in gear because it isnt opening up/returning. you or someone else will have to disassemble the clutch and rebuild it again. cleaning everything inside the clutch.
Wes
Old Feb 5, 2005 | 07:32 PM
firehouse5's Avatar
I tried the shim and i put a new spring in but still have a problem maybe i'am not putting the shim in the right place???
firehouse5
Old Feb 5, 2005 | 07:48 PM
the shim needs to go between the secondary clutch sheaves..
Old Feb 5, 2005 | 07:53 PM
then it is most likely NOT belt tension... take the primary clutch off and squeeze it together. if it doesnt return all the way than that is your problem.
Old Feb 5, 2005 | 08:01 PM
firehouse5's Avatar
I have the sportman 2000 with ebs i had it apart but can't seem to find the right place for it as for the clutch it's a brand new one and seem's to work great
firehouse5
Old Feb 5, 2005 | 10:18 PM
jeffro206's Avatar
have your clutch off set checked they may be misaligned. causing belt to drag on drive clutch. also, what idle speed? maybe too high?
also, ebs belt has little or no deflection.runs tight for braking.
Old Feb 6, 2005 | 01:31 AM
firehouse5's Avatar
Thank's i get a creep in all my gear's i put a new drive clutch and driven i thought that would help no go also a new belt i have asked a few guy's and they say that you can't shim an ebs system any help would be great if some one can tell me how to stop this problem
firehouse5
Old Feb 6, 2005 | 01:51 AM
dontgetbehindme's Avatar
Can I ask a dumb question. Is the belt you put on the right size? Just a thought.
