Knocking out the washer
Old Feb 6, 2005 | 11:40 PM
spyder6's Avatar
Default Knocking out the washer
ok, so, so i dont screw up anything on my pretious 800, im putting the old 500 back to work. I got this 6.5x17 foot car trailer behind the barn and whenever it gets even misting out with rain, we cant pull the 7000lbs diesel up the hill or it'll make 5" deep ruts in the ground. so, a ATV would be better to pull the trailer out.
so, on the old pre-hitch quads that had the little toung lip thingamabober on the back, theres a slot to put a 3/4 inch thread ball in there. my dads trailer uses a 1" thread. there is this washer thats in it that looks like if you hit it hard enough with a hammer it'd pop out, but it looks liek it might be welded in place. my question is is there anyway i can pop that out to fit the 2 5/16" ball for the trailer there so i can haul it out from behind the barn easy, or do i have to buy a reciver for the hitch on my 800 and port the hole out to 1" with a drill bolt from good ole wallyworld
Old Feb 6, 2005 | 11:43 PM
silverbullet2005's Avatar
you can go out and buy a 1" unibit drill bit to open the hole out to use the larger hitch ball.
Old Feb 6, 2005 | 11:52 PM
spyder6's Avatar
im probebly going to end up getting the hitch for the 800 and just port that hole, shouldent be too hard, and if i totaly screw it up atleast i didnt screw up the 8000 doller quad! lol
Old Feb 7, 2005 | 12:14 AM
thewayout420's Avatar
could you use a piece of thick steel and bolt it to what you have now and drill it out to accept the bigger ball?
bmxatv10
Oct 14, 2022 06:23 PM
bzdok1234
30
Feb 23, 2016 01:55 PM
01ssls1
Sep 22, 2015 06:50 AM
merryman
Sep 19, 2015 03:15 AM
Countrygirl1976
Ask the Editor
Jul 13, 2015 12:19 AM
