Sport Quads Discussions on sport quads.
sprocket
Old Feb 8, 2005 | 08:41 PM
yamaharaptor350's Avatar
Default sprocket
Is there a big increase low end if I put a 12 tooth front sprocket on.
Old Feb 8, 2005 | 09:02 PM
drgnerth's Avatar
Default sprocket
It will gain you extra low end bu you will lose top end. If you mostly ride trails I say go for it. The cost is minimal if you dont like it.
Old Feb 8, 2005 | 09:57 PM
Default sprocket
thanks and i do manily ride trails. Is it easy to put on
Old Feb 9, 2005 | 10:08 PM
KingRacing's Avatar
Default sprocket
very easy
Old Feb 9, 2005 | 11:09 PM
Default sprocket
doesnt the bolt holding on the sprocket turn? How do u unlosen it without the bolt turning on u
Old Feb 10, 2005 | 09:47 AM
farmboyxc's Avatar
Default sprocket
my tool of choice is an impact wrench, other wise you need to put it in gear/ apply parking brake (if you still have the chain on) impacting a rachet with a hammer might do the trick. you'll have to flatten the keeper first. Disclaimer: I'm not a mechanic [img]i/expressions/face-icon-small-smile.gif[/img]
Old Feb 10, 2005 | 03:57 PM
Default sprocket
when u flaten the washer thing do u bend it on the new sprocket? and doent it weaken it
Old Feb 10, 2005 | 10:55 PM
farmboyxc's Avatar
Default sprocket
yea, you flatten it on the nut again when you put it back on. you can bend it in a different spot if you think its going to break the washer.
Old Feb 10, 2005 | 11:37 PM
KingRacing's Avatar
Default sprocket
yea the impact wrench does a good job of taking them out, if this is the first time changing the sproket the washers should still be in good shape. Remember not to flatten them to much because they might be hard to bend back in spot. They are there to help it from comign loose during those real ruff rides :~|
buddieboy
Dec 9, 2016 05:50 PM
merryman
Sep 19, 2015 03:15 AM
Canamaniac!
Sep 15, 2015 06:19 PM
Old Deer Hunter
Sep 2, 2015 01:39 AM
Dammar
Aug 26, 2015 07:12 PM
