how can i make my 300 faster?
Old Feb 11, 2005 | 04:20 PM
300exridingboy's Avatar
Default how can i make my 300 faster?
i have a 05, 300ex it has a full dg exhaust, nerfs, bumper and i want to make it go faster to keep up with the people i ride with with out spending to much money.............please help!
Old Feb 11, 2005 | 04:40 PM
Sangr1's Avatar
IF YOU HAVE NOT RE-JETTED THE CARB, DO THAT ALONG WITH K&N AIRFILTER. ALSO OPEN UP THE AIR BOX/LID. INSTALL REV LIMITER AND THEN WORK WITH THE GEARING. IF YOU ARE RUNNING 22 INCH STOCK TIRES, PUT A 14 TOOTH UPFRONT OR GOT TO A 37 REAR. WITH ENGINE MODS YOU CAN START PLAYING WITH THE GEARS. IF YOU ARE RUNNIG ON TIGHT TRAILS, LEAVE THE GEARING AS IS AND COMPLETE THE OTHER MODS. ALL THESE SMALL CHANGES ADD UP....IF YOU ARE GOING TO GO THIS FAR CONSIDER A WEB CAMSHAFT AS WELL...WHAT QUADS ARE YOU HAVING TROUBLE KEEPING UP WITH. IF ITS LIKE A 450R OR A 450Y THEN ANY AMOUNT OF MODS WILL NOT HELP VS. THE COST INVOLVED....
Old Feb 11, 2005 | 05:09 PM
im having truble witha 400ex and a scrambler 400
Old Feb 11, 2005 | 05:46 PM
Sangr1's Avatar
TROUBLE IN A STRAIGHT LINE, OR SHORT COURSE.....400 EX IS A PRETTY STRONG RUNNING QUAD.......IF IT IS STOCK AND YOU PUT ALL THE MODS I LISTED YOU WILL STILL FALL A LITTLE SHORT.....RIDING SKILLS HAVE A LOT TO DO WITH IT......TRY AND DUMP THOSE 22 INCH TIRES FOR 20 AND RE-GEAR......INSTALL THOSE MODS AND THEN SEE WHAT HAPPENS....TRY REMOVING EXCESS WEIGHT AS WELL...IT IS A SITUATION THAT YOU ARE TRYING TO MAKE A MODIFIED SMALLER ENGINE RUN WITH A LARGE ENGINE...IT CAN BE DONE JUST COSTS $ AND SO CREATIVITY.....
Old Feb 11, 2005 | 08:38 PM
Ntrx250xJ's Avatar
High compression piston
better cam/ bigger intake valves& better springs
Better carb
good air filter/no air box lid
add that to what u have and u might be able to keep up. My new 300ex has about 2grand worth of motor mods. When its all together and running ill let you know how it does vs other quads.
Old Feb 11, 2005 | 08:49 PM
abcarr90's Avatar
Ya im looking for mods for a TRX250EX...PM ME
Old Feb 11, 2005 | 09:29 PM
KingRacing's Avatar
i dont have problem keeping up with people and here are my mods are below. (if you want a better top end, instead of the 12 tooth get a 14...)
Old Feb 13, 2005 | 08:37 PM
NichelsonRacing87's Avatar
hey man lay off the caps, they don't make your point any better
also you can build a 300ex to beat a stock 400ex, 22" tires will get you more top speed over the 20's, also you will have a little hard time beating a Scrambler 400, they are pretty quick for being auto's, and if you wanted to try to beat a Scrammy 500 you might as well forget it lol.
later man
Old Feb 14, 2005 | 01:36 AM
Rydehertz's Avatar
you'll keep up but not beat..what kind of riding are you doing?
Old Feb 16, 2005 | 04:41 PM
Exrider22's Avatar
Trust me its an up hill battle, buy a 400
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
Backwoods_badass
Aug 3, 2015 01:34 AM
HondaR24
Jul 16, 2015 10:45 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
