Thieves Got My ATV Rear Rack Bag. Need Suggestion
So I got to get a new one. I want a soft one that buckles to the rack instead of velcro. The velcro just doesn't hang on after a while.
What do you guys know.
I have two fender bags that work well, hold a lot of stuff, but scratch up fenders and you have to step over them every mount/dismount.
ROCK... insert a piece of plywood cut to the shape & size of the bag, into the bottom of a soft rack bag... then you can slip some bolts through the bottom... the trouble I have with the soft bags of any kind, is the straps eventually rip out the bag, from rough riding, & heavy items in the bag... you can either sand smooth the edges of the plywood, or put some foam pipe insulation around the edges of the plywood... doing this will make your bag last years longer, & definately deters theives, as they'd need tools to remove the bag... good luck with what ever model you should choose...
