250R Headstay
Old Feb 13, 2005 | 09:54 AM
ZillaRider02's Avatar
Default 250R Headstay
I am completely rebuilding my '89 TRX250R. When I pulled my cylinder (Stock jug, major portwork) I found a crack just above the left rear base nut. Also, my left front motor mount was cracked, and my bottom mount was loose. I was told the headstay contributed to the crack in the cylinder. The cylinder has already been welded up and reinforced. It was suggested to me to install the headstay between the frame rails for frame stability, but not to bolt it to the boss in the head. Any one else run without a head stay?
Old Feb 13, 2005 | 10:59 AM
250ex's Avatar
I haven't run one in years. The head I use is RK Tech and it doesn't have headstay. I jump and haven't had any problems.
Old Feb 13, 2005 | 11:36 AM
Thanks, I have new front motor mounts and plenty of lock tite for the rest of the bolts, so I will try it without the stay.
Old Feb 13, 2005 | 08:12 PM
NichelsonRacing87's Avatar
i been running without one too, you don't need it so don't let it keep causing you problems, it doesn't help anything i can think of
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
Traci Carnahan Simmons
Aug 9, 2015 03:00 PM
CRamshaw777
Jul 18, 2015 05:46 PM
