How to bypass the Rev Limiter
Old Feb 21, 2005 | 03:55 PM
mnorton's Avatar
Default How to bypass the Rev Limiter
Does anybody know where the Rev limiter is and how to bypass it on a 500 Xplorer/Sportsman.
Your help is appreciated.
Thanks,
Mike
Old Feb 21, 2005 | 07:56 PM
ftwflh's Avatar
Unplug the black wire coming from the limiter box.This will disable the rev limiter but you will still have to use the overide button for 4x4 in reverse.
Old Feb 21, 2005 | 08:04 PM
oldsmoboat's Avatar
But where is it?
Old Feb 21, 2005 | 10:33 PM
ftwflh's Avatar
There are 2 boxes one is the reverse limiter the other is the Voltage regulator.The rev limiter has 3 wire the regulator has 4.The one on my Scrammy and TB is under the front hood.On my old Sportsman it was down by the radiator behind the shroud.Not sure on yours.
Joe454
Nov 20, 2020 01:19 PM
DGNAZ
ATV Expeditions
Jun 22, 2017 04:20 PM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
