Dinli Performance issue
Old Feb 21, 2005 | 06:09 PM
Fosters's Avatar
Default Dinli Performance issue
Looking to get a little more ponies out of my daughters Diamondback 90. I originally thought she would out run her cousin's Raptor 80, not the case. I've been to Maximum-RPM, I seen the exhaust I want but no air filter for the stock carb. Is there an aftermarket one or do I have to upgrade the carb and filter together?
Old Feb 21, 2005 | 10:53 PM
90cckaseadad's Avatar
You have to check out hetrick Racing at WWW.Hetrickracing.com. They are the best and will help you with the right parts.
2004 Olympics 2nd place overall 90cc prod
2004 GNC ST National Champion 90cc prod
2004 GNC TT 4th place overall 90cc prod
2004 GNC MX 5th place overall 90cc prod
2004 GNC XC Ironman 3rd place 90cc prod
2005 Olympics overall Champion 90cc prod
www.zacstrongracing.com
Old Feb 22, 2005 | 11:12 AM
LT80's Avatar
LT80 Expert
OR, better yet, WRH racing.com ask for Billy
Don't get that maximum pipe.
If your looking for performance from a pipe and carb, your looking in the wrong spot anyways IMO. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Feb 22, 2005 | 02:39 PM
TRexTommy51's Avatar
Foster, I use to live i Littlerock. ANyway, The pipe's you can get from maximum-rpm were not designed for the stock carb in mind. Really not any of the pipes out there that are good pipes run very well with a stock carb. ANyway, At the minimum you will need a new carb 24mm, air filter ( I like Uni), a pipe (Billy put the Koso on Koty's new engine, we were running the Ex-pipe), clutch springs to 2K rpm, stiffer torque spring, 16 tooth front sprocket and rollers in the 5.0 gram range. Maybe lower. Hope this helps.
Old Feb 22, 2005 | 09:01 PM
Fosters's Avatar
Thanks for all the help. I'll give Billy at WRH a call and check out Hetrick's site. I was under the impression Hetrick specialized on Kasea and Eton's.
Old Feb 23, 2005 | 07:57 AM
Well, Rich has been doing Kasea's for awhile. He has two Dinli's at the Nationals this year.
Old Feb 23, 2005 | 12:34 PM
Psycmike's Avatar
Are you pretty happy with your Dinli? I wished I'd taken a look at them prior to buying my son's Sportsman 90. I always have some buyers remorse. Anyway...how much did you pick it up for? I've emailed Dinli and they won't send me a price listing. I may keep this 90 for a year and then sell. We'll see.
Old Feb 23, 2005 | 02:38 PM
Dinli will not sell direct to you. They will direct you to a dealer. Calling there 1-800 number will work better than e-mail for that.
Old Feb 23, 2005 | 03:45 PM
Fosters's Avatar
Hey Tommy how complicated is it to install a clutch kit from Billy @ WRH? We talked about some things for me to do first, which one of the things was the clutch kit.
Psycmike... As far as price in So. Cal, the price is $1895.00. Maybe high, maybe low, but I like the Dinli mini over the Yamaha and Honda minis.
Old Feb 24, 2005 | 08:06 AM
If all you are concerned about is out running the Yamaha, then get a 16 tooth front sprocket. The clutch kit will take you about two hours to complete if you have never done one. In So Cal I would see if someone is willing to come over for a beer or two and look over your shoulder to make sure you are doing it right.
