scrambler wheel size?
Old Feb 21, 2005 | 07:47 PM
storks's Avatar
Default scrambler wheel size?
whats the biggest you should go to. im looking at replacing just the backs and i like the dirt devils 24*11*10 on itp c series would this mess up any 4*4 engagment or should i do the stock size. i personaly love the 489s for the front but the stock 22s on the back are weak imo. any help? whats t he max size for the back with out cutting or having the wheels rub? thanx
Old Feb 21, 2005 | 07:55 PM
scramblerXrated's Avatar
if your going to go larger tires in the rear, i think you will need to keep the fronts an inch bigger than the rears, as they are from the factory. other wise, you might run into future 4x4 issues.
the same goes for gearing(sprockets sizes). you dont really want to be messing with the sizes unless you know what is the proper size.
there is someone on this forum that has the precise caulculations of what should be the proper tire sizes and/or gearing, when going with larger tires ona 4x4 scrambler.
you might benefit from doing a topic search on this forum. youll see what im talking about.
X
Old Feb 21, 2005 | 07:59 PM
storks's Avatar
thank you good thing i didnt go and order them. thank you for your help i guess ill save up some money as i do not want to mess the 4*4 engament up. btw it is a 500 scrambler in casr you dont know
1986Vmax540
Jul 9, 2021 09:53 PM
toonces
Aug 5, 2015 05:55 PM
rcappie4
Jul 18, 2015 07:51 AM
maxjung
Jul 13, 2015 05:11 PM
