500 3x4
Old Feb 22, 2005 | 06:59 PM
oneshot7525's Avatar
Default 500 3x4
My 96 sp500 has only been running on 3 wheels. The front left side doesn't kick in. One of my friends said something about a nut inside the hub that he got replaced. What do you guys think i should look for. Also when you are driving normally and have the four wheel drive button pushed in, should all wheels spin all the time, or should just the rear until you loose traction and have the others kick in? HELP!
Old Feb 22, 2005 | 07:23 PM
ZMan079's Avatar
Default 500 3x4
My neighbors had a problem like that on their Xplorer, I think it was the wire that runs to the hub...
ZMan079
Old Feb 22, 2005 | 08:06 PM
Default 500 3x4
What... did the whole wire have to be replaced or was there just a bad connection.
Old Feb 22, 2005 | 09:50 PM
scramblerXrated's Avatar
Default 500 3x4
check and /or change your hub fluid. thats the most common of problems. if that not the problem, track down the wiring to the hub. but my money is on the fluid!
X
Old Feb 22, 2005 | 10:57 PM
tyler711's Avatar
Default 500 3x4
This topic comes up all the time. Try a search, you will find a lot. Try searching for "hub" "not engaging" "no awd" that kind of thing.
Tyler
Old Feb 24, 2005 | 02:33 PM
ZMan079's Avatar
Default 500 3x4
The neighbor kid knocked the wire off I guess after riding through some very, very thick brush.....
ZMan079
