Rich at idle
Old Feb 23, 2005 | 08:22 PM
SPORTSMAN70003's Avatar
Default Rich at idle
will being rich on the pilot make me have a little bog on take off.
Old Feb 23, 2005 | 08:36 PM
jeffro206's Avatar
sp70003, if you're too rich it can cause some what of a bog, kinda like if it was too lean. try turnig the adjustment screw for idle mix in some and see if it helps. if you have to run it in almost all the way to make it better, you prolly need to rejet.
Old Feb 23, 2005 | 08:38 PM
MnFriesen's Avatar
check your plugs
Old Feb 23, 2005 | 08:40 PM
Plugs are black at idle and you can smell it flooding.
Old Feb 23, 2005 | 08:58 PM
20045SP500HO's Avatar
Yes, it also may be bog because the plug is to wet. You could also try a hotter plug.
Old Feb 23, 2005 | 10:00 PM
I think I'm going to adjust the fuel screw its 2 turns out maybe I'll try 1.5 turns out. I also might get a hotter plug.
Old Feb 23, 2005 | 10:10 PM
Smitty4's Avatar
If it's rich, you'll want to turn the screw IN.
IN = leaner
OUT = richer
If it runs better turning the screw OUT, then that means that you were too lean.
Old Feb 23, 2005 | 10:13 PM
Thanks I have it 2 turns out and going to try 1.5 turns out thats turning it in a 1/2 a turn.
Old Feb 23, 2005 | 10:22 PM
Smitty4's Avatar
My bad--I should have looked closer at your post!
All I saw was "turn out", but you were talking about From the fully seated position. now I get it. [img]i/expressions/face-icon-small-blush.gif[/img]
Keep trying different settings, going 1/2 turn at a time. Experiment with different settings and you'll eventually have it running mint.
Old Feb 23, 2005 | 10:26 PM
I wish I had a tool that would let me adjust the screw with the carb on. I have the 40mm carb of an HO and its bigger than the stock carb and its hard to get in there.
