axle u joint replacement
Old Feb 25, 2005 | 03:32 PM
Thumper33's Avatar
Default axle u joint replacement
96 sportsman 500
I found a bad u joint on one of my rear axle shafts today. I have the suspension mostly apart anyway, so I thought I might as well pull the whole shaft to replace the joint. Then I got thinking... will the CV shafts from the newer ones be a direct replacement? I'm not sure if it's really worth it since I've gotten really good at replacing u joints in my jeep anyway. If I even can change over, is the CV a more efficient joint?
Also, does anyone know a part number for the u joint if I can just run down to the local napa and grab one?
The one that's bad is the upper (or inner).
Old Feb 25, 2005 | 03:43 PM
Thumper33's Avatar
oh, and is the fluid going to come out the axle shaft hole when I pull that axle shaft out? I still can't get it out of there. Is there a best way to get it out?
Old Feb 25, 2005 | 05:30 PM
Thumper33's Avatar
ok, I'm really confused now. I got the shaft out, (there was a retaining bolt), and took the U joint first to napa (no, we don't have anything), and then the dealer (that doesn't look like our diagram).
It looks like the dealer snows a CV on one side, and a u joint on the other. They had that u joint in stock, but it was a totally smaller size.
Mine has a u joint on both sides, and they couldn't even find a way to get me the part for it.
Old Feb 25, 2005 | 06:48 PM
jeffro206's Avatar
t33, here are the 2 part # 1590257 is out towards the wheel end, 1590256 is the end towards gearcase
toonces
Jul 28, 2015 01:58 PM
metal249
Jul 28, 2015 09:35 AM
Peter_
Jul 18, 2015 07:06 AM
musselmark
Jul 17, 2015 02:40 PM
Rider252
Jul 6, 2015 03:37 PM
