sand tires for the V
Old Feb 25, 2005 | 08:14 PM
Budwsr's Avatar
Default sand tires for the V
Hey I don't ride allot on the Dunes but I do go often, with that being said I don't want to spend an arm and a leg on paddles
does any have any sand stars on thier V or some of the other paddles if so what size should I get?
do I want a widder first # or larger 2nd?
example : 22x 11x10?
or 20 x 12 x 10
anyone have the sand stars happy with em?
Old Feb 25, 2005 | 09:44 PM
Squatcher's Avatar
Do not get the 20'S. I have two V's both with Sand stars on them. the best tire and wheel for the V is the hauler 24" with the duglas 11" wide rims. But that will cost you one arm. I have a set of each standard rim with and the 11" on my sand stars. The stardard gets more bite and makes for the front end to come up a lot. I haven't riding the 11's that much yet but they seem to be better and don't digs holes in the sand. You will have to use the starting fluid trick to mount the tire on that rim though. Make sure you get aleast the 22" paddles
Old Feb 26, 2005 | 04:03 AM
Kawierider's Avatar
If you get the 24" Skats with the 11" rims, be sure to get some 2.5" spacers for the rear. The big Skat Traks hook up real well, but they make turning difficult. By spreading out the rear wheels, initiating a power slide becomes easier. This will greaty improve turning and sliding.
Old Feb 27, 2005 | 11:47 AM
Budwsr's Avatar
so basically I want the largest #s for example 22x11x12? or 22x11x10? I know I would need to get bigger rims with the 12s
anyone know what the weight is on rims and tires on the sand stars?
Old Feb 27, 2005 | 12:45 PM
rivermud's Avatar
22x11x10 (for example)=== 22 is the diameter of the tire, 11 is the width of the tire, and 10 is the size wheel you have. So a short fat tire is 20x12x10
Old Feb 27, 2005 | 02:13 PM
Kawierider's Avatar
A taller tire gives more float for the heavy V-Force. Skat Trak makes a 24" Extreme that works very well for the V-Force. In fact, it was made specifically for this quad. I bought my set through these folks. They had the package to my door in 3 days.
Action Offroad
Old Feb 27, 2005 | 10:07 PM
HappywithVForce's Avatar
I have the 22" Sand Stars. They do very well in the dunes. I do not worry so much when crossing more rocky areas, as they are a durable tire.
Old Feb 28, 2005 | 03:55 AM
tmm2good's Avatar
I also went for the 22inch sand stars, for as much as I use them, they work great.
Old Feb 28, 2005 | 05:50 AM
Budwsr's Avatar
hey i think I'm gonna go with the sand stars, 22x11x10 set up anyone know where I can get a sweet deal on wheels and tires?
Hey Happy w/the vforce what elevation are you running at? still working on dialing in the Muzzy
I figure with the money I save I can put more mods into it, I really don't ride the dunes that much
Old Mar 1, 2005 | 03:31 AM
tmm2good's Avatar
I bought mine at actionoffroad.com in utah, a friend bought them at paddletires.com or something like that for about 10 bucks less for the package. Do you ever go up to Walden?
