No rear brake on 2005 sp
Went for a ride today and tried the rear brake on my 700 EFI and nothing, i mean nothing at all. Why would this be i checked everything i can see and all looks good. The spring is attached and everything seems to be inplace. It has 348 miles on it. Any help would be good!! Thanks!!
From the Service Manual:
Poor Brake Performance:
Air in system
Water in system (brake fluid contaminated)
Caliper/disc misaligned
Caliper dirty or damaged
Brake line damaged or lining ruptered
Worn disc and/or friction pads
Incorrectly adjusted lever
Incorrectly adjusted stationary pad
Worn or damaged master cylinder or components
Improper clearance between lever and switch
I would look at the adjustment for the rear, see if there is any play. You may have to bleed the system also.
Air in system
SixSpeed5
8
Aug 2, 2015 05:38 PM
