Flat tire Scrambler
Old Feb 27, 2005 | 06:13 PM
berommen's Avatar
Default Flat tire Scrambler
Hi,
One of my rear tires on my Scrambler 500 is always runing flat, I checked for damage but there was no vissible damage.
I inflate my tires to 400 grams? one of my friends has a Bombardier DS 650 with the same problem.
He told me fast cornering could let escape air with these low pressure tires ?
Does anyone had this problem?
Old Feb 27, 2005 | 09:09 PM
tyler711's Avatar
You could use some kind of tire sealant to fix your problem. Only thing is that they leave a residue inside the tire and wheel that is tough to clean if you decide to change tires or wheels. I've never tried SLIME, but I have only heard good things about it. I usually use that aerosol stuff in a can that seals + inflates, but supposedly it dries in the tire, so it doesnt fix future leaks and makes a big mess. The Slime stays wet so it reseals, but some people say any type of sealant can un-balance your tire.
So if you can't find the leak (valve stem, tiny hole, etc), i'd say that sealant would be the way to go.
Tyler
Old Feb 28, 2005 | 12:27 AM
BigBadScrambler's Avatar
Take the tire off, fill it up with air, and submerge it in a tank of water. If you have a leak, you should see air bubbles from the source. Look carefully at the bead of the rim. A lot of times you can get dirt or debris stuck in the bead
Old Feb 28, 2005 | 08:05 AM
scootergptx's Avatar
Supersock
Hired Gun!
Had the same problem with a front tire. Like BigBad says, the tank is the best way to check. On my tire it was the valve core. Just happened to have 4 new stems in the truck, so we swapped them out and didn't have to take the tire off. Fixed the problem.
Old Feb 28, 2005 | 08:12 AM
XtremeSkier's Avatar
ya i have 2 stock tires that do it now, both rears, otherwise my fronts have plugs in them. They all have holes in them but idc, i only use them in the winter and i ride rarely in the winter, plus i have my holeshots, but mine first started loosing air cuz i would get grass caught in the rim and i had clipped a few trees, which bent my rim up[img]i/expressions/face-icon-small-tongue.gif[/img]
switzomatic
Aug 24, 2015 12:57 PM
mitchxc700
Aug 19, 2015 02:41 AM
scram5050
Aug 19, 2015 02:19 AM
mitchxc700
Aug 10, 2015 09:26 PM
maxjung
Jul 13, 2015 05:11 PM
