shifting on the sportsman....
Old Feb 28, 2005 | 03:26 AM
polarisbear500's Avatar
Default shifting on the sportsman....
on my 99 500, after it gets warmed up from riding, i have a hard time shifting it out of low or high to neutral and somtimes to reverse, i have to pull hard sometimes just to get it out of gear...any suggestions????
Old Feb 28, 2005 | 10:43 AM
20045SP500HO's Avatar
idle RPM to high?
Old Feb 28, 2005 | 02:31 PM
no, i had that checked at the polaris shop a few months ago when i had some other work done on it
Old Feb 28, 2005 | 04:14 PM
sorry ... i'll have to think about it for awhile ... i'm not sure.
Old Feb 28, 2005 | 05:28 PM
KRAYZEE's Avatar
i don't think the warming up has any thing to do with it ,but, i would adjust your shift linkage you must do both low inside and high/reverse outside i plow with my 6x6 sportsman 500 alot shifting front back front back all the time i have to adjust once and awhile not saying this is your problem may be worth checking good luck!!
Old Feb 28, 2005 | 06:31 PM
ttaylor's Avatar
I would pretty much say your shift linkages are out of alignment. common thing on the quads with the dual shift linkages.
Old Mar 1, 2005 | 11:31 AM
this may sound dumb.... but how do i do that ??????
Old Mar 1, 2005 | 12:31 PM
GST97's Avatar
If you follow the shifter down to its base, you will see a black box that it connects to.
Off the back of that box, there are 2 rods. There are tie rods on both ends of both rods.
To adjust, simply take 2 (10mm I think) wrenches and crack the locking nut free on the rod on both sides.
Then use a pair of pliars and spin the center rod section until it is at a point where everything engages nicely. Then tighten the nuts back up.
You may also have a problem inside the shifter box itself. on my 99 300, I had a peg break off the ball on the bottom of the shifter which gave the shift handle itself way too much play and it didn't like to shift so well.
More than likely however... your problem is just in the linkage.
-Chris
95wolv
Sep 27, 2024 12:00 PM
Clint Russell
Sep 25, 2015 03:20 PM
patrick.oc123
Sep 16, 2015 03:45 AM
BigCam
Sep 16, 2015 01:53 AM
patrick.oc123
Sep 15, 2015 02:45 PM
