anyone jett a polaris 500??
Old Mar 1, 2005 | 05:07 AM
killzoneq2's Avatar
Default anyone jett a polaris 500??
My scrambler 500 is stock and wnating to jet it. What is a good jetting that I might want to run in it. And what kind of response/gain shold I expect?
Old Mar 1, 2005 | 07:53 AM
quadsnsleds's Avatar
Are you going to pipe it?? If not, you can't atler it for any more power. Jetting depends alot on elevation. I'm barely above sea level ( couple hundred feet ) but for your question, my 500 scrambler with a slip-on pipe & K&N is 160 main, needle 2nd from bottom, & fuel/pilot screw @ about 3 turns out. Hope this helps.
Old Mar 1, 2005 | 04:06 PM
killzoneq2's Avatar
Not piping it yet, thought about a twin-air and cutting a hole in the air box. K&N say that you dont have to jet the bike if you use one of there filters. Not sure what to do. My main gole is to get more throttle response out of the bike. What would be a good method for this?
Old Mar 1, 2005 | 07:36 PM
OffRder15's Avatar
If you want more throttle response I recommend just going with the HPD airbox/carb mod for $114 at www.hpd-inc.com. You'll get better throttle response as well as a 2 HP gain. While you're at it throw in a K&N w/ outerwear.
A clutch kit is also a good idea if you want a stronger "get up and go." Again HPD has that for you too.
You won't gain much if any power from just an airfilter or rejet.
Cole Hadden
Jun 15, 2025 09:05 AM
Ramman1
Aug 11, 2022 01:53 PM
NoJoke
Aug 9, 2015 12:39 PM
Polaris Side by Sides
Jul 30, 2015 12:14 PM
maxjung
Jul 13, 2015 05:11 PM
