Transmission in bad shape
Old Mar 1, 2005 | 10:03 PM
EXRiderEX's Avatar
Default Transmission in bad shape
I own a 250ex and a while back i was messing with the transmission bolt on the front end of the motor. I was trying to stiffen up the transmission because i didnt like how it was sounding normally. Well i guess i did something wrong and it is really hard to shift and the bolt on the motor wont budge. I have read the owners manual and i tried everything. It still wont budge or loosen up. I thought about taking it up to our local honda dealer but i really wanna save the money and fix it by myself. Advice anyone? Anyone with a 250ex or anyone who knows what i am talking about please help. Thanx
Old Mar 1, 2005 | 10:24 PM
110Wearwolf's Avatar
i did that to. i cant move the screw.
are you able to push the shifter down and like pop hte clutch because on mine i cant
id really like to know how to fix that
Old Mar 1, 2005 | 11:07 PM
EXRiderEX's Avatar
it sounds like ours are in the same shape. i would really wanna know how to fix it too. i liked it better how it was, and i miss the easy wheelies. also on mine you cant pop the clutch now either. anyone else got some info?
Old Mar 2, 2005 | 07:27 AM
dzzy's Avatar
Sounds like you guys were messing with the clutch adjustment. If you turn the adjustment screw clockwise too far, it may be possible to uncouple it from the detent underneath the front engine cover. At that point it may be nearly impossible to restart the adjustment bolt without cross threading it. You may end up removing the front engine cover to fix your problem. The proper clutch adjustment is turn the screw counterclockwise until you feel resistance, then back in a quarter turn, then tighten the locknut.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
exmotocrosser
Sep 13, 2019 06:12 AM
r1pilot83
Sep 27, 2015 07:38 PM
cboler9
Sep 24, 2015 08:35 PM
WilliamBos
Sep 22, 2015 04:07 PM
