Stock Warrior Air Filter
Old Mar 3, 2005 | 10:36 PM
Warrior02man's Avatar
Default Stock Warrior Air Filter
Ok, I have a stock 02 Warrior. I just opened up my air filter box and I saw a Red UNI air filter... I took it out and yep.. it was UNI. It has no prefilter/wrap, but it was a red UNI air filter with the metallic small grid-like cylinder being covered by it where the air comes in. Is this stock, or did the person before me put the UNI on it? Thx.
Should I keep it or go with the K & N pro flow set up?
Old Mar 3, 2005 | 11:21 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
a foam filter doesn't need a prefilter... and UNI's aren't stock :-p if u get a K&N you need a prefilter unless u are riding dunes only..
Old Mar 3, 2005 | 11:41 PM
When should I clean it? What should I use on it.. water?
Old Mar 3, 2005 | 11:54 PM
ImASissy's Avatar
i switched to the k&n, but when i had my foam filter, I made sure i cleaned it everytime. you can clean it in gasoline, water, or soap water. or thats what i used at least
STLyamwar
Jul 25, 2020 04:44 AM
manuelrivera
Aug 8, 2015 04:34 PM
Reactant
Jul 27, 2015 07:45 PM
Reactant
Jul 16, 2015 10:29 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
