Oil Injection Block Off Question
Old Mar 3, 2005 | 10:38 PM
hondabigred's Avatar
Default Oil Injection Block Off Question
I'm wanting to block off the oil injection on a 88 TrailBoss 250. My question is do I really need the block off plate. Could I just drain both the oil and gas tanks. Then I would just put the premix in the gas tank and leave the oil tank empty. Would this hurt anything or has anyone done this? And also I was thinking I could just plug the oil line up and wouldn't need a plate. I know the plates are only like $16-$20, but if you don't really need it, I don't see paying the money. I'm doing it for reliability reasons and not weight saving. If anyone has any info let me know.
Thanks
Old Mar 3, 2005 | 10:43 PM
jeffro206's Avatar
by just emptiing the tank you can cause 2 things, first would br an air leak which is bad for 2 stks. second is the pump can sieze and cause more problems from being ran dry. spend the 20 bucks and save yourself the agravation later. also, you will need a single line throttle, some have gotten away with tieing the end up, but it can hang up and hold the throttle open.
Old Oct 5, 2008 | 08:16 AM
muddrr's Avatar
Default Oil Injection Block Off Question"></title><script src=
can i ask a ? ..im doing the same..iv bought the block off plate...now am curious of what lubricates the bottom end of the engine without oil injection pump installed ...& what ratio should i run my premix....
bigred20653
Oct 2, 2015 10:05 AM
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
nastyblaster100
Sep 13, 2015 01:19 PM
John Reed
Sep 9, 2015 03:46 AM
