Behind stator / crank bearing grease ???
Took some time today and removed our deactived Oil Pump from our Pred-90. Before I reassemble, what grease (if any) should be re-applied behind the stator / right crank bearing area?
For a visual of this area, surf:
- Press Here for BEFORE picture -
- Press here for AFTER picture -
If this small crank bearing area needs to be re-packed with grease, what type of grease, and to what level? Re: 1/4 level, 1/2 full, etc.
Many thanks.
Many thanks.
Thanks Newnick.
I checked the E-Ton & Kolpin Service manuals and each of them showed "clean pictures". And I didn't see any mention of adding grease / oil to the bearing or the oil pump gear. Very weird. I think it's left over grease from the factory oil pump gear lubrication as well...
Thanks Newnick.
Task all done. It's back together again. Only thing to do is wait for our air filter to dry then, "fire her up!!!".
For pictures, surf: http://community.webshots.com/album/130997005nxNiAA
Happy surfing...
Happy surfing...
