27' 589 M/S Tires wont fit on '04 Sportsman 700?
Old Mar 6, 2005 | 10:04 PM
JJonJon's Avatar
Default 27' 589 M/S Tires wont fit on '04 Sportsman 700?
I have a 2004 Polaris Sportsman 700, it is completely stock, I just bought 27' ITP 589 M/S Tires from Highlifter.com, well I took the 4-wheeler and the tires to a local tire shop up the road and they said that the tires would not fit, and that the rub against the tie rod, and they I would have to get spacers for them to fit... I have seen many '04 Sportsman 700s with my same tires and they did not need spacers .. Does anyone out there have these tires on their SP 700?..
Any help is greatly appreciated
27' ITP 589 M/S Tires?
Old Mar 6, 2005 | 10:12 PM
MaineMudder3's Avatar
Did you get skinnies up front? If you did then you'll be all set. Don't listen to tire places..they don't know a thing about wheelers!
Old Mar 6, 2005 | 10:26 PM
JJonJon's Avatar
Yeah Im pretty sure, I got 27x9-11 on the front and 27x and 27x11-12's on the back.. so i hope i didn't waste my money, im going to the Polaris dealer on Wednesday, i hope its not a wasted trip.
Old Mar 6, 2005 | 10:28 PM
SPORTSMAN70003's Avatar
If they are the 27x10x12 then I would say they are rubbing the tierods and if you have the 27x9x12 on the front they will be close to rubbing. You can pick up some spacers problem solved.
Old Mar 6, 2005 | 10:43 PM
JJonJon's Avatar
Do they come in diff sizes on 27'?.. when i purchased these tires I figured they only came in one size on the front and a lil bigger size on the back
Old Mar 6, 2005 | 11:31 PM
silverbullet2005's Avatar
If you put the new tires on stock wheels they will probably rub whether they are the 9's or the 12's. you will need either aftermarket wheels or wheel spacers. you should have done a search on the subject before your purchase. I just installed 27-9-12 mudlites on the front and 27-12-12 mudlites on the rear of my 2004 700EFI mounted on the ITP type 6 wheels. they do not rub the tierod. I installed 2" strut spacers to lift the front end up so they wouldn't rub the fender flares. you can check out my gallery to see pics of my quad and the spacers.
Old Mar 7, 2005 | 12:09 AM
JJonJon's Avatar
Thanks bro, do i need aftermarket wheels and spacers, just wheels, or just spacers? I need my info before Wednesday. Thanks and anymore replys will be appreciated
'27 ITP 589 M/S Tires?
Old Mar 7, 2005 | 12:10 AM
elkbow's Avatar
Silverbullet is right....on the stock wheels, you will probably rub whether you have 9's or 10's...on aftermarket wheels, the 9's should clear, the 10's will probably rub...
just pick up some wheel spacers....then you'll be all set...
and yes, the tires come in 27x9-12 and 27x10-12....
Old Mar 7, 2005 | 12:24 AM
JJonJon's Avatar
Thanks alot elkbow and silver
Old Mar 7, 2005 | 05:40 AM
mtpockets's Avatar
if i remember correctly, the stock tire on the '04 is 25"? so jumping up 2 sizes i think your next problem will be rubbing the front fenders be the floorboards.
when i bought 26" Outlaws from Highlifter they rubbed terribly there. after awhile it got old and i put the stockers back on.
good luck with yours though!
-MT[img]i/expressions/face-icon-small-smile.gif[/img]
Jmuddin284
Jan 19, 2026 07:16 AM
Big bousse
Sep 26, 2015 10:42 AM
baysport
Jul 23, 2015 11:37 AM
rcappie4
Jul 18, 2015 07:51 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
