whats the proper way to ajust warrior air blead
Old Mar 7, 2005 | 04:15 AM
gwinnridder's Avatar
Default whats the proper way to ajust warrior air blead
well went and cleand the carb on my warrior and just had to play with the air blead whats the right way to ajust it
thanks
shane
Old Mar 8, 2005 | 12:58 AM
bump
Old Mar 8, 2005 | 02:32 PM
95wolv's Avatar
I assume you mean the idle mixture screw on the bottom of the carb just before the intake boot. A good place to start is 2 or 2.5 turns from seated, then warm up the motor, and run it up to speed in 2nd gear, then let it coast in gear, without pulling in the clutch. If it pops or backfires while slowing down, open the idle mix up 1/4 turn at a time until it stops. If it doesn't pop, turn it in until it does, then go back 1/4 turn. That will get you set up for the best idle and throttle response off idle.
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
craacker
Sep 9, 2015 04:32 AM
ylomnstr
Sep 4, 2015 05:02 PM
