reeds 2 stroke 400
Old Mar 7, 2005 | 05:08 PM
Newoldkid's Avatar
Default reeds 2 stroke 400
Will the reeds being out on a 400 2 stroker keep it from starting if they are bad. The bike cranks is getting fuel and fire but won't start. Big backfire and loss of power then when shut down would not start. REplaced head gasket and cleaned carb and new plug and air filter also new fuel and oil filters. Still wont start. Found out about the reed valves going into the cylinder in a shop manual. Any thoughts here experianced ones.
Old Mar 7, 2005 | 07:51 PM
POLARISFREAK's Avatar
Yes if your reeds are broken or shredded it would keep it from starting!
Old Mar 7, 2005 | 08:04 PM
jeffro206's Avatar
when the bike backfired it could have blown the seal on the clutch side out causing it to quit and not restart. check the reeds and if ok, look at the seal.
as for your ? on the 300 sprocket - won't hurt it a bit, will help on the trails you loose just a little topend speed but not much
Old Mar 8, 2005 | 12:48 AM
Newoldkid's Avatar
Thanks for the help. Will check it out tomorrow. Appreciate the time.
exmotocrosser
Sep 13, 2019 06:12 AM
QuadRiders
Oct 22, 2015 04:13 PM
exmotocrosser
Sep 26, 2015 08:18 AM
BYC
Sep 25, 2015 02:10 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
