Trailblazer suspension
Old Mar 10, 2005 | 08:23 PM
ambrosie's Avatar
Default Trailblazer suspension
My son has a 250 trailblazer and I'd like to soften the rear spring some more it's already on the lowest part of the cam , any ideas?
Old Mar 10, 2005 | 11:44 PM
quadsnsleds's Avatar
Yea, tell him to bulk up & put on some muscle to weigh it down a little. Just kiddin'. Have you researched for a softer sping or a dual rate spring. A dual rate would ride soft & smooth, but still resist bottoming on hard hits.
Old Mar 11, 2005 | 09:57 AM
BubaHyde's Avatar
Depending on the year you could get a scrambler rear fox shock
2002 and prior trailblazer machines can use a fox shock from a 99 and prior scrambler/sport.
this is a grand improvement over the factory trailblazer unit. I did it to our 2001 trailblazer.
2002-up already has the long travel suspension, but to my knowledge the 250 never came with the Fox shock.
You could get a fox shock for 2003-up trailblazer 250 off any Scrambler after Model Year 2000.
If you don't have a long travel modle, you can convert it by changing out the swing arm.
The long travel swing arm mounts the shock farther back for clearance reasons. A long travel shock will not just bolt on with out swaping swing arms also. I did this swap on my 1999 scrambler.
The long travel units are by far the most cushieeeee Factory units. Mostly due to the fact of the duel rate springs.
neo27ny
May 14, 2018 12:19 PM
Robinhood
Dec 26, 2015 10:28 AM
bigred20653
Sep 19, 2015 02:11 PM
chewy78
Sep 8, 2015 10:37 AM
tmboy
Technical and How-To Articles
Sep 1, 2015 09:20 AM
