broken winch cable
Old Mar 13, 2005 | 09:53 AM
fwd1122's Avatar
Default broken winch cable
Does anybody have any ideas on how to temporarily repair a broken winch cable. It snapped down by the hook, and was from lots of plowing this winter. I want to repair it just in case we get more snow. I did order another one, but wont be in until the end of the week. Thanks
Old Mar 13, 2005 | 10:21 AM
Don49's Avatar
Go to Home Depot or Lowes or a good hardware store & you can buy the parts for wire rope you'll probably need a metal piece that looks like a tear drop & 2 wire rope clamps for the size of your cable. Be sure not to use just 1 clamp, use 2. Hope this helps.
Old Mar 13, 2005 | 12:23 PM
soupcan's Avatar
A quick, easy fix, would be to take the cable and slide two ordinary nuts onto the cable. Make sure the holes in the nuts are big enough to thread the cable back into after the winch hook is looped through. After the hook is looped into the cable and the loose end of the cable is looped back into the nuts, take a hammer and smash the **** out of the nuts down on the cable. Guarenteed, the cable will never slip back through the nuts. You will eventually have to cut your hook free some day. But you will only loose a few inches of cable and the 2 nuts will save you a trip to town.
Old Mar 13, 2005 | 09:13 PM
tyler711's Avatar
I used two of these, but the next size up. Just be sure to keep that thimble on the wire where it goes through the hook. I just keep the right sized wrench in the quad; if the cable breaks I just move the clamps.
Also, may I suggest that you keep that broken/spliced cable on there all winter. It will most definetly break again, why ruin another cable? Put the new one on in the summer so you don't cut your hands while winching. Just get some nice clamps like I have there^^ and keep repairing it in the winter.
Old Mar 14, 2005 | 09:17 PM
simonsez's Avatar
When my cable broke at the beginning of winter, i pulled the cable off and went to home depot and bought a tow strap for $12.00, I cut the hook off of one end and wraped the strap around the drum of the winch, i have been using that all winter , it's awesome, no worry of it breaking. Hope this helps!
Old Mar 14, 2005 | 11:17 PM
tyler711's Avatar
Yeah, the strap is the way to go if you don't need the winch for non-plow use in the winter.
Johnny Mac
Aug 15, 2019 03:13 PM
Whitelx1
Oct 2, 2015 10:55 PM
cboler9
Sep 24, 2015 08:35 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
mrmickman123
Technical and How-To Articles
Aug 30, 2015 10:37 PM
