Rear sprocket is not centered, ... why?
Old Mar 14, 2005 | 12:24 AM
DesertViper's Avatar
Default Rear sprocket is offset, ... why?
I was adjusting and lubing the chain today on my 2005 DS 650, and I noticed that the rear sprocket, or rear sprocket mounting hub, are not centered. If the sprocket is in one position the chain is too loose, but if the sprocket is turned 180 degrees the chain is too tight. Nothing looks bent, and everything rotates smoothly and quietly, and I can't feel any vibrations riding the DS. When I jack up the rear of the DS and rotate the rear tires I can visibly see that the rear sprocket is not centered. The sprocket mounting bolts are tight, and have never been removed, as I am running the stock rear sprocket.
Anybody know what causes this, and what it takes to fix the problem?
Thanks,
DesertViper
Old Mar 14, 2005 | 12:37 AM
THEBOM's Avatar
THEBOM Racing. If it don't scare you a little, it's not going fast enough !!!
Default Rear sprocket is not centered, ... why?
Check your axel bearings.
Old Mar 14, 2005 | 03:52 AM
yamahawarriormods's Avatar
SOUNDS WEIRD i would have to day its bent
Old Mar 23, 2005 | 04:14 PM
Well I determined that the problem had to be something with the axle bearing in the back of the swingarm, which requires special tools to replace properly, so I took the DS to the dealer to have him do the work. It turns out that I have a broken and worn axle bearing in the rear of the swingarm.
mywifesquad
8
Sep 21, 2015 08:20 AM
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
snowolson
Aug 31, 2015 03:51 PM
WilliamBos
Jul 22, 2015 04:20 PM
joeyupton
Jul 14, 2015 11:51 AM
