Sport starter
Old Mar 14, 2005 | 08:19 PM
oghma's Avatar
Default Sport starter
I tore into the task of replacing the brushes on my starter and found oil in the starter. Is this normal?? I have never seen this before. I opened the drain plug on the starter and nothing came out. I also open the drain plug that is right below the starter pinion gear and only get a couple drips. I can only assume that there is a seal leaking in the starter. Please help!!! This is the first starter that I have worked on.
Old Mar 15, 2005 | 10:46 AM
oghma's Avatar
Anyone??
Old Mar 15, 2005 | 10:54 AM
dailyrider's Avatar
Was there oil in the recoil or flywheel area? Because this is the only place it can come from. If so you you will have to replace the seal that is behind the stater.
Old Mar 15, 2005 | 11:16 AM
oghma's Avatar
There wasnt that much I would expect more than just enough oil to be "wet". Will it hurt anything to run the starter the way it is for the weekend?? I planned on just making sure there was oil for the flywheel/recoil casing and tearing it back down next week.
Customer Service #1
May 15, 2020 08:46 AM
akguy31
Aug 31, 2019 04:34 AM
Coondoog
Technical and How-To Articles
Sep 9, 2015 01:51 PM
MrTrashMan2U
1) Engine problems..
Sep 9, 2015 11:11 AM
Pahuntman
Sep 5, 2015 11:07 AM
