Question about clutch fiber discs?
Old Mar 16, 2005 | 12:54 AM
jackass650's Avatar
Default Question about clutch fiber discs?
I had several steel plates that were worn so I just ordered new ones and my cdrom says if the whole pack of friction discs has to measure at least 27.5 mm, mine measures 29mm but do I need to check and make sure they are not warped like the steel plates and if so how do I check them? thanks
Old Mar 16, 2005 | 09:47 AM
Eaglecollector's Avatar
Not sure how you could check the fibers warpage other than to measure the stack height like you did. You seemed to be well within the limits though. 3.75mm warpage + 27.5mm = 31mm max stack height and your at 29mm
Old Mar 16, 2005 | 03:52 PM
jackass650's Avatar
ok thanks ealgecollector, maybe i should check them on a peice of glass like the steel ones
ghost civic
Jan 15, 2020 07:43 AM
4464
Aug 21, 2015 01:46 AM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
ghost civic
Jul 15, 2015 10:48 PM
200es
Jul 10, 2015 09:09 AM
