hard to move 350
Old Mar 16, 2005 | 10:08 PM
500scrambler4x4's Avatar
Default hard to move 350
i just got my 350 together and it was a little hard to move the crank so i just kind of started to assemble my motor and one i got the sides on the crankcase on i went to turn it and was like it was seized. i was told that the endplay was off. what does that mean. and how do you adjust it? any info would be great.
Old Mar 16, 2005 | 10:10 PM
yamahawarriormods's Avatar
i would make sure your crank seals are seated properly this could make it hard 2 turn it over
Old Mar 16, 2005 | 10:16 PM
it turns hard without them in though. first i greased the seals then let it sit with oil in it i came back and it was the same to ,i removed the seals and still the same. so what do you think is wrong?
Old Mar 16, 2005 | 10:23 PM
jeffro206's Avatar
i thought you were still taking it apart? lol
im kinda confused is it tight with one or both case halves on? did you replace the bearings?
need little more info, then i can help u more
Old Mar 16, 2005 | 10:37 PM
well i said ill try it tomarrow but got bored and went out to the garage with a friend got it open like you said with a tourch and heating up the bearings, cleaned it up really good. took a good look at what needs to be done then i started to put it back together and thats when i noticed it was binding up. the bearings are all in good shape...........................sorry might be a dumb question but im still learning but what are case halves?
Old Mar 16, 2005 | 11:00 PM
jeffro206's Avatar
case halves are the 2 sides of the crankcase. did you by any chance have the bearings off the crank? also, make sure they are completely cleaned out if you are not replacing them.
MeadowlarkFarm
Nov 27, 2019 08:40 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
rawbdiggity
Sep 7, 2015 12:05 PM
Elkaholic
Sep 6, 2015 02:44 PM
cdstang
Aug 31, 2015 07:52 AM
