Lift kit question - Sportsman 500
Old Mar 17, 2005 | 02:18 AM
Predsports500's Avatar
Default Lift kit question - Sportsman 500
My buddy has a 2004 Camo Sportsman 500....... He can buy a used set of rims with 27" Blackwaters mounted on them cheap right now... I know the rears will fit fine but will he need a liftkit for the front?... How about putting some 1 1/2 inch spacers under the springs...... Anyone done this on their quad with success ? ... I know that he will need to re-clutch after ... What's everyone running with those tires on the 500 ?...... Thanks in advance
Old Mar 17, 2005 | 08:26 AM
handycap's Avatar
I ran 27" on my '00 500 magnum with a primary spring out of a '94 400L.
Used washers on the front to lift it like you mentioned. Made a shock extention on the rear.
Worked great. Did'nt like a stall spring in ft clutch. Put a lt blue spring in rear clutch to keep it from up shifting so quick.
Old Mar 17, 2005 | 02:31 PM
moosehunter's Avatar
Most set ups I've seen (and used) are in the 1" to 2" lift range. This is usually accomplished with spacers placed under the front coils. Personally, on my 04.5 SP500HO, I run a 2" front spacer lift and stock springs with 27" 589's with great results. This provides plenty on clearance for the tires and enough preload to firm things up a bit out front. This also "levels" the bike out for a "better" look.
As far as wheels, unless your buddy has or is getting aftermarket wheels with more offset, you'll need to look into some wheel spacers to avoid contact (rubbing) with the tie rod ends.
So far, I have not felt the need for clutching mods. Even with the oversized tires, power still comes on right off idle and top end has remained unchanged. Others may have had different results in this department, but it all boils down to riding style and what's important for you.
Good luck with your project...
Old Mar 17, 2005 | 06:51 PM
silverbullet2005's Avatar
I am running 27" ITP Mudlites on ITP type 6 wheels with the 2" strut spring lift spacers which I made. check out my gallery for pics of them. post your email address and I will get with you about them.
Cole Hadden
Jun 15, 2025 09:05 AM
1966F100
Jul 12, 2015 03:08 AM
tporath
Jul 11, 2015 12:31 PM
toonces
Jul 11, 2015 12:01 PM
200es
Jul 10, 2015 09:09 AM
